February 23, 2023 at 10:10 am
amir.mb1377
SubscriberHello. How i should considering 3 series elements for mat-197 in ls dyna software??
February 23, 2023 at 4:30 pm
Andreas Koutras
Ansys EmployeeHere are some sample keywords that may help.
$ MAT (Material) cards
*MAT_SEISMIC_ISOLATOR Â Â Â Â Â Â Â Â Â Â
$ sliding isolator
     1   2000.0    0.0    0.0    0.0   0.005    1.e8     0
   1.0e5
    0.2    0.10    0.5             0.150       Â
$ elastomeric isolator
     2   2000.0    0.0    0.0    0.0   0.005    1.e8     1
   1.0e5
    0.0    0.0    0.0    0.0    0.0    0.0  Â
   30.e3    0.05        0.150 Â
$ sliding isolator with radii
    10   2000.0    0.0    0.0    0.0   0.005    1.e8     2
  -1.0e5
    0.2    0.10    0.5    0.5    0.5   0.50         1.e5
                        0.1   0.40    0.30
$ SECTION cards
*SECTION_BEAM
     1     6    0.0    0.0    0.0    0.0
$    vol    iner    cid     ca   offset   rrcon   srcon   trcon
   0.125    10.0     0    0.0    0.0    0.0    0.0    0.0
     2     6    0.0    0.0    0.0    0.0
$ PART cards
*PART
sliding isolator
     1     1     10     0     0     0     0     0
*PART
sliding isolator
     2     2     2     0     0     0     0     0
*PART
    10     1     10     0     0     0     0     0
$ NODE cards
*NODE
    1       0.0       0.0       0.0    0    0
    2       0.0       0.0       0.0    0    0
    3    0.24974091       0.0       0.0    0    0
    4    0.24974091       0.0       0.0    0    0
   13       0.5       0.0       0.0    0    0
   14       0.5       0.0       0.0    0    0
$ ELEMENT cards
*ELEMENT_BEAM
    1    1    1    2    0
    2    2    3    4    0
   10    10    13    14    0
$ BOUNDARY cards
*BOUNDARY_PRESCRIBED_MOTION_NODE
     2     1     0     1    2.0     0    0.0    0.0
$ Â Â Â Â 2 Â Â Â Â 2 Â Â Â Â 0 Â Â Â Â 2 Â Â Â 2.0 Â Â Â Â 0 Â Â Â 0.0 Â Â Â 0.0
     4     1     0     1    2.0     0    0.0    0.0
$ Â Â Â Â 4 Â Â Â Â 2 Â Â Â Â 0 Â Â Â Â 2 Â Â Â 2.0 Â Â Â Â 0 Â Â Â 0.0 Â Â Â 0.0
$ Â Â Â 14 Â Â Â Â 1 Â Â Â Â 0 Â Â Â Â 1 Â Â Â 2.0 Â Â Â Â 0 Â Â Â 0.0 Â Â Â 0.0
    14     2     0     1    2.0     0    0.0    0.0
*BOUNDARY_SPC_NODE
     1     0     1     1     1     0     0     0
     3     0     1     1     1     0     0     0
    13     0     1     1     1     0     0     0Â
February 24, 2023 at 2:49 pm
amir.mb1377
SubscriberHello. You don't have the image of the isolator modeled in ls dyna. And that you don't have the file of these samples that you sent? -
February 24, 2023 at 7:55 pm
February 24, 2023 at 8:16 pm
amir.mb1377
SubscriberHello. The model consists of 3 beam elements with zero length. What does the distance between 3 and the element depend on? Should the mesh be added to the elements?
- The topic ‘Triple pendulum’ is closed to new replies.
5819
