Ansys Free Student Software
trave su ansys workbench
    • ChiDB
      Salve,sto modellando una trave in c.a. su ansys workbench, mi è stato consigliato di disegnarla su autocad e indicare le armature come linee per poi dargli la sezione. Però quando lo esporto in formato iges e lo apro in ansys nel modello riesco a vedere solo il solido e non le linee,come posso fare per riuscire a visualizzarle o a disegnarle?
    • Ashish Khemka
      Translated version:
      Hi, I'm modeling a beam in c.a. on ansys workbench, I was advised to draw it on autocad and indicate the reinforcements
      as lines and then give it the section. But when I export it in iges format and open it in ansys in the model I can only
      see the solid and not the lines, how can I manage to view or draw them?
    • Gary_S
      On the Project schematic, right click on Geometry > Properties > Line Bodies (Enable)
      Line Bodies should import into Mechanical. Note that the Corss Sections are not assigned and not defined.
      Right Click on the Model Branch > Insert > Cross Sections > Select and define a cross section as needed.
  • The topic ‘trave su ansys workbench’ is closed to new replies.
