Photonics
Photonics
Transmission equation used in FDTD and MODE
    • gpsar
      I know the equation Lumerical uses for transmission is shown here
      https://optics.ansys.com/hc/en-us/articles/360034405354-transmission-Script-command but when you solve for the Poynting vector what is the result? Does P = |E|^2?
    • Amrita Pati
      The equation for Poynting vector is given as:
      Amrita
    • gpsar
      Hi Amrita,
      Thanks for your answer. But what is the result of integrating the Poynting vector, since you are only taking the real part?
      • Amrita Pati
        The Poynting vector is integrated over the monitor surface to determine the total power through the monitor cross-section. The total power is then normalized to the source power to calculate the transmission.
        More details can be found on the following page:
        Integrating the Poynting Vector
        Amrita
  • The topic ‘Transmission equation used in FDTD and MODE’ is closed to new replies.
