September 2, 2021 at 5:08 am
Amith_Anoop_Kumar
SubscriberWhen I ran a simulation with static analysis and tarnsient analysis with same boundary conditions ,but in transient the same pressure load was given in steps but got lesser defromation and stress vales in transient compared to static. Why is that so
September 2, 2021 at 8:57 amVigneswaran Sridharan
Ansys EmployeeHi,
A static structural analysis determines the displacements, stresses, strains, and forces in structures or components caused by loads that do not induce significant inertia and damping effects.
On the other hand, a transient structural analysis (also called time-history analysis) is used to determine the dynamic response of a structure under the action of any general time-dependent loads. You can use it to determine the time-varying displacements, strains, stresses, and forces in a structure as it responds to any transient loads. The time scale of the loading is such that the inertia or damping effects are considered to be important.
Vignesh
September 2, 2021 at 9:04 amAmith_Anoop_Kumar
Subscriberso just on a short note as inertia and damping effects are considered hence we get lower stress values right. Thanks a lot
September 3, 2021 at 1:04 ampeteroznewman
SubscriberThe default analysis setting for Static Structural has Large Deflection turned Off.
The default analysis setting for Transient Structural has Large Deflection turned On.
Change Static Structural to have Large Deflection On and solve that model to see how the result changes and if it is closer to matching the Transient Structural model.
If the results don't match, then run the Transient Structural model for a longer end time and make sure damping is used and the results should converge on the new Static Structural result.
May 6, 2023 at 3:57 pm
Johnson Ezenwankwo
SubscriberHello Peter, can I may you a question?
May 6, 2023 at 9:52 pmpeteroznewman
SubscriberHello Johnson Ezenwankwo.
Yes, you may ask a question, but unless the title of this discussion is exactly what your question is about, it is best to start a New Discussion and provide a descriptive title and put a lot of detail in your post.
May 17, 2023 at 8:57 pmJohnson Ezenwankwo
SubscriberMay 17, 2023 at 9:12 pmpeteroznewman
SubscriberHello Johnson Ezenwankwo,
Please click the Start a New Post button on the General Mechanical Channel.
You need to put a lot more description into your post than what you have above. Say what the analysis type is, the loads, the boundary conditions, the materials. I don't know much about RVE but someone who does might provide an answer.
May 17, 2023 at 10:19 pmJohnson Ezenwankwo
SubscriberThanks, Peter. I have created a new post about this issue. I await your feedback.Â
May 18, 2023 at 1:19 ampeteroznewman
Where is your New Post? I don't see it under General Mechanical.
You can put a link to your post in your reply.
May 18, 2023 at 3:10 pmJohnson Ezenwankwo
Subscriberhttps://community.ansys.com/?status/49639-49639-1684361619/
May 18, 2023 at 3:36 pmpeteroznewman
SubscriberYou posted to the Feed which is not widely read.Â
Go to the Learning Forum. On the Learning Forum go to the General Mechanical section. Then press the Start a New Post button. Make the title of the post RVE Help or something like that.
Please label your figure to identify all the face names. Use arrows to point to the features in the image that you find are wrong.
May 18, 2023 at 5:24 pmJohnson Ezenwankwo
SubscriberHello Peter, I have just created a new post under Mechanical with added annotation to the graphics attached.Â
December 1, 2023 at 5:55 amAli aviation.khademi
SubscriberHello Peter, I have deformed a plate in static structural, now, i want to keep it deformed and do the creep analysis. Where should i transfer the solution? I mean should i transfer it to the structural transient?(the option of "transfer solution to" just offer explicit dynamics and other analysis but not the transient is an option). I have tried to do it manually by dragging from solution to setup, but after opening the model, the geometry of my model is undeformed (unlike the explicit that when i transfer static solution to it , it is deformed).
December 1, 2023 at 8:27 amErKo
Ansys EmployeeThis is a very old post and your question is not directly related to the original post - open up a new discussion.
Closing post
Erik
Viewing 13 reply threads- The topic ‘Transient vs static’ is closed to new replies.
5044
1754
1387
1248
