April 15, 2024 at 6:43 am
n2390n
SubscriberHello, I'm facing a problem that other users have encountered.
Based on previous posts, I've noticed that other users have encountered similar issues. I've read through their posts, but I still can't seem to resolve the problem myself.
I checked the guidelines in Workbench. The handbook provides a formula that suggests users should use appropriate timestep sizes. However, I'm not sure about this cuz my results seem incorrect.(negative TEMP)
timestep :20
A five-layer rectangular prism model (8000*1600*1 um) with a mesh size of 0.4 um, where the top layer provides heat flux.
and the initial temperature of the model is 22
And after confirming the material properties, there are no errors in the settings. Could anyone tell me where I may have missed something in the settings that led to results contradicting physical phenomena?
April 15, 2024 at 8:32 am
ErKo
Ansys EmployeeÂ
Hi
Except of using smaller time step (try that , so calculate dt time step as shown here : https://www.linkedin.com/pulse/calculating-solution-settings-transient-thermal-analysis-eric-stamper)
also the mesh and it size can influence.
See here for more info:
https://simutechgroup.com/transient-thermal-analysis-with-non-physical-temperature-results/
All the best
Erik
April 15, 2024 at 12:41 pm
April 15, 2024 at 12:57 pm
ErKo
Ansys EmployeeHi
I would suggest to really look through the posts in detail:
Mesh related: https://simutechgroup.com/transient-thermal-analysis-with-non-physical-temperature-results/
Time step related: https://www.linkedin.com/pulse/calculating-solution-settings-transient-thermal-analysis-eric-stamper
All the best and hope this info helps
Erik
April 16, 2024 at 6:18 am
n2390n
Subscribergot it, thx alot
Will try it through
- The topic ‘transient thermal’s solution problem’ is closed to new replies.
5694
1891
1419
