TAGGED: ANSYS-Transient, ansys-transient-thermal, transient
September 4, 2024 at 8:17 am
n2390n
SubscriberHello,
I've been working on a transient thermal analysis, but the temperature data from this cross-section seems weird.
This figure shows an overview of my mesh settings.
 I applied different mesh sizes in this model to reduce running time.
The blue region is my heating area.
Any suggestions would be greatly appreciated. Thx!
should I do diff mesh type or mesh size should not differ too much
cuz this case is about cost 5 days....
September 4, 2024 at 11:26 am
Ashish Khemka
Forum ModeratorHello,
It would be difficult to comment without looking into the model (Ansys employees cannot download the model). Some suggestions - what if you use linear and uniform mesh? Do you see an unexpected behavior?
Ashish Khemka
September 5, 2024 at 4:24 am
n2390n
SubscriberIseeÂ
The model will look like this when viewed from the side, width = 10um
and i wanna know surface temp. between no.4 & no.5
The current results confuse me, here's some pic of my result
at specific time, the highest temperature is about 32 degrees at the surface between no.4 & 5
and this is the path temp. data in the same surface
ÂHere is the problem, why there's big temperature difference at the lower interface when the heat is conducted from top to bottom.Âthx anyway
September 12, 2024 at 9:04 am
n2390n
Subscriberneed some help here
September 12, 2024 at 9:34 am
Ashish Khemka
Forum ModeratorHi,
Can you check the heat flux vector plot for how heat is flowing?
Ashish Khemka
September 17, 2024 at 11:23 am
September 23, 2024 at 6:42 am
n2390n
SubscriberAny suggestions would be highly appreciated
5964
1307
