February 7, 2024 at 10:11 am
sachin.kumar
SubscriberHi,
Why harmonic analysis stress results are differ from transient structural (sinusoidal load) analysis (Non-linear large deflection on) even I have run transient analysis long enough to get steady state response.
details of load and settings are given below.
Harmonic analysis: acceleration in x- direction = 5g, damping ratio = 0.03Â first i have run modal and got frequency range 1000 to 4000Hz than i have run harmonic and evaluate von-mises stress at 1000Hz result shows 1.51Mpa max value.
In next step, I ran transient structural with Non-linear mat properties with large deflection ON/OFF both.
load: acceleration =49050*sin(2*pi*1000*time)). damping control Beta coeff 9.53e-06 calculated basis 0.03 damping ratio
min. time step cal: 1/(20*1000) = 0.00005sec. in graph control No of points = 20*1000*time.
I ran for 1 sec and got periodic type results of von mises stress and max value comes out to be = 0.73Mpa which is lower than harmonic.
my question is why there is a difference in harmonic and transient eventhough i got steady state periodic value which we can say harmonic.
as per my understanding non-linear mat properites should not impact the result becaouse stress value is well below the plastic region.
can anyone explain why there is a difference in both harmonic and transient structural????
February 8, 2024 at 3:44 pm
danielshaw
Ansys EmployeeHarmonic analyses are linear. It appears that you ran a non-linear transient.
February 9, 2024 at 4:01 am
sachin.kumar
Subscriberyes I ran non-linear transient, but how it will affect the results even the stress values are still in elastic region
February 8, 2024 at 3:58 pm
dlooman
Ansys EmployeeLarge deflection wouldn't be included in the harmonic. You could have numerical damping in the transient. What's is the gamma value on the TINTP command?
February 9, 2024 at 7:23 am
sachin.kumar
SubscriberI have tried both
large deflection OFF: 1.13Mpa
Large deflection ON: 0.73Mpa
Gamma = 0.1
February 9, 2024 at 2:33 pm
dlooman
Ansys EmployeeSo, you should be comparing results with large deflection off to get an apple to apple comparison. Gamma = 0.1 is like a log decrement of 0.1. Damping ratio is about equal to log decrement divided by 2pi. So in the transient you have more damping. How different are the two stresses? What's the maximum harmonic stress?
February 12, 2024 at 4:05 am
sachin.kumar
Subscribermaximim harmonic stress = 1.58Mpa@5g load and 3.17Mpa@10g load
Max transient structural stress = 0.78Mpa @5g load and 2.32Mpa @ 10g load
there is a constant difference of about 25%
so as per your understanding the large deflection is off and what about gamma = ??
February 13, 2024 at 8:45 am
sachin.kumar
Subscriberi tried with gamma = 0.005 as well but the results are still same
February 13, 2024 at 3:50 pm
dlooman
Ansys EmployeeSince the transient is linear, shouldn't the 10g result be 2X the 5 g result? Is it possible there is another nonlinearity, such as nonlinear contact?
February 14, 2024 at 3:39 am
sachin.kumar
Subscriberoh sorry that was typo mistake it is 1.16MPa instead of 0.78MPa
we have bonded contact in both transient and harmonic
February 14, 2024 at 3:10 pm
dlooman
Ansys EmployeeThat's a good verification that the transient is linear then. Just to confirm, the excitation is at 1000 Hz and you run the transient for 1 second with a time step of 0.00005 secs. Even with auto-time stepping the solution should probably maintain this time step since the response frequency should be close to 1000 hz. Is that the case? The time step doesn't open up? A possible source of confusion on the harmonic side is that in recent years we have switched from damping ratio (dmprat) to constant structural damping coefficient (dmpstr) for a full harmonic. If you are actually using constant structural damping coefficient, it produces only half the amount of damping that damping ratio of the same value does.
February 15, 2024 at 3:45 am
sachin.kumar
SubscriberThanks Dave for prompt reply.
Initial time step = 0.001
min time step = 0.000001
max = 0.1
time step is auto control and it is varying with time
I got your point i think we should keep the time equal to 0.00005 for complete iteration.
as we have sinusoidal loading if time step will be more than above then there might be slip in magnitude of load.
am i right??
February 15, 2024 at 2:14 pm
dlooman
Ansys EmployeeI just wanted to make sure we didn't have a large integration error. A time step of 0.00005 would insure that.
February 16, 2024 at 4:13 am
sachin.kumar
SubscriberNow I am getting 3.13Mpa max stress which is very close to harmonic results 3.17Mpa
February 16, 2024 at 5:24 pm
dlooman
Ansys EmployeeSo, we can declare victory?
February 17, 2024 at 3:48 am
sachin.kumar
Subscriber????
- The topic ‘Transient structural (Non-linear) Vs Harmonic analysis (modal based)’ is closed to new replies.
