June 1, 2025 at 4:39 am
Xbuddyin
SubscriberHi everyone,
I'm working on a 2-way FSI setup in ANSYS 2019 R3 involving a plate composed of 14 solid bodies, connected using Shared Topology in SpaceClaim. I need to define Fluid–Solid Interfaces on the top and bottom faces of the plate to couple with Fluent (transient, dynamic mesh).
Problem: In Transient Structural, when I define the FSI interface using a Named Selection of faces, ANSYS treats it as a volume. A question mark (?) appears, and the setup fails to update. Strangely, the same face selection works fine in Static Structural.
What I’ve Tried:
Verified Shared Topology is active
Suppressed fluid bodies in the structural system
Ensured face-only Named Selections
Recreated the interface multiple times
Question:
Why does Transient Structural interpret face selections as volumes in this case? How can I ensure proper face-level FSI scoping across multiple connected bodies?
Any help would be appreciated.
June 3, 2025 at 4:57 pm
Xbuddyin
What I’ve Tried:
Question:
June 5, 2025 at 2:23 pm
Ravikrishna K V S
Ansys EmployeeFor any question mark status on any object, The good practice is to highlight the same object and click on " show errors" tab. Followed by this, looking at Messages tab should give a clue.
3266
1031
984
859
798
