Transient Structural FSI Interface Shows Volume Instead of Face
    • Xbuddyin
      Hi everyone,
      I'm working on a 2-way FSI setup in ANSYS 2019 R3 involving a plate composed of 14 solid bodies, connected using Shared Topology in SpaceClaim. I need to define Fluid–Solid Interfaces on the top and bottom faces of the plate to couple with Fluent (transient, dynamic mesh).
      Problem: In Transient Structural, when I define the FSI interface using a Named Selection of faces, ANSYS treats it as a volume. A question mark (?) appears, and the setup fails to update. Strangely, the same face selection works fine in Static Structural.
      What I’ve Tried:
      • Verified Shared Topology is active
      • Suppressed fluid bodies in the structural system
      • Ensured face-only Named Selections
      • Recreated the interface multiple times
      Question:
      Why does Transient Structural interpret face selections as volumes in this case? How can I ensure proper face-level FSI scoping across multiple connected bodies?
      Any help would be appreciated.
    • Xbuddyin
      Hi everyone,
      What I’ve Tried:
      Question:
