May 23, 2026 at 7:47 pm
dani.besednjak
SubscriberCan I use the
NEQITcommand in a Transient Structural analysis, or is there an equivalent command? When I try to use it, I get an error and the analisys wont start. -
May 23, 2026 at 10:48 pm
peteroznewman
SubscriberYes you can use the NEQIT command in a Transient Structural analysis, what number did you use with it?Â
If you used a command
NEQIT,1
that could cause the solution to fail to converge.
Use a number larger than 15. You can go over 100 if you need it. Â
If you don't use the NEQIT command, the solution control uses 26 so forcing it to use 1 can usually break the ability of the solver to converge.
1310
