September 18, 2023 at 9:26 pm
aliborhan
SubscriberHello,
 I am writing a UDF that includes a DEFINE_PROFILE macro for a transient simulation. My goal is to update the variable viscous resistance of a porous media during each time step. Since DEFINE_PROFILE macros are executed during every iteration within every time step, what can I do to ensure that the macro executes only once per time step? I tried using "first_iteration," but it didn't work within the DEFINE_PROFILE macro. Also, If I enter a large value for the UDF Profile Update Interval in the Run Calculation panel, I cannot be certain whether this value is greater than or less than the maximum number of iterations required for convergence.
Thank you in advance for your guidance!
September 20, 2023 at 1:33 pm
aliborhan
SubscriberHello,
September 21, 2023 at 2:45 pm
aliborhan
SubscriberAny thoughts on this?
Thanks!
September 22, 2023 at 10:16 am
Luca B.
Forum ModeratorHi, DEFINE_PROFILE is executed at any iteration because you need to provide a boundary values to porosity. So it need to compute the corresponding value anytime.
How to do modify the viscous resistance? is it time dependent?Â
Some ideas
- can you modify it only with Expression without an UDF. So you can calculate it without running the UDF?
- Another possibility, you can try. You can use a DEFINE_EXECUTE_AT_END  that is run only at the end of all time step. You can compute it the new viscous value, save it into a global variable and so make it accessible to the DEFINE_PROFILE macro.
Let me know if this suggestion are useful
Luca
- The topic ‘Transient simulation: How to execute DEFINE_PROFILE macro once per time step?’ is closed to new replies.
5824
