January 21, 2025 at 5:05 pmtjhidalgoSubscriber
Hello all,
I am new to using Discovery and am seeking some help.
I am currently working on a design project that involves analyzing the heat transfer of a jacketed mixing tank. Currently I have the tank body and the impeller. I'm wondering why I recieve this error when switching the simulation from steady-state to transient. I know it has something to do with the area around the impeller but I'm not sure exactly what the problem is.Â
January 22, 2025 at 4:59 amDevendra BadgujarForum Moderator
Hello,Â
The errror message says that the rotating fluid condition that you have applied does not work while doing time depeendent fluid simulation. Currently only steady state is possible with rotating fluid condition.
DevendraÂ
- Unable to attach geometry 2024 R2
- Data Center Simulation
- Overlapping contact face
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Inventor 2025 files
- Issue Seeing Explore
- solidwork parameters for optimization in ansys
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- Fan flow simulation
1897
807
599
591
366
