August 16, 2023 at 6:51 am
dang-cuong.phan
SubscriberHow to carry out transient thermal electrical caculation in workbench 2022?
August 16, 2023 at 8:48 am
Sampat Kumar
Ansys EmployeeHi Dang,
Will you please explain the problem in detail? it's not clear from the above-mentioned detail what type of module you want to use. Please explain the problem in the detail so that we can suggest how can be your simulation flow or which module would be suitable for your analysis.Â
SampatÂ
August 16, 2023 at 9:47 am
dang-cuong.phan
SubscriberI simulate the heating process in a furnace, using electrical energy (applying a voltage on an Ohm-resitance).
In workbench 2022R1 I can only set up a stationary process. My process is transient. The temperatur in furnace should increas by time.
Howe can I create a transient simulation of thermal electrical heating process in workbench?
August 17, 2023 at 6:07 pm
August 18, 2023 at 4:54 am
dang-cuong.phan
SubscriberHi Sampat, I need transient calculation of electrical heating process, transient thermal simulation alone is useless in my project. In ansys classic the couppling electrical-thermal is standard and works well.
- The topic ‘transient simulation electrical heating’ is closed to new replies.
5709
1896
1419
