January 29, 2024 at 5:26 pm
ayoub.naoui
SubscriberHello everyone,ÂI am trying to use Lumerical FDTD with Lumerical HEAT to simulate the photothermal heating and cooling . Following from this example in plasmonic nanostructures (Photothermal heating in plasmonic nanostructures – Lumerical Support), I have first simulated a rectangle on a substrate in FDTD with a SMF fiber to determine the absorbed power (Pabs: using the Pabs adv analysis group) in my rectangle. I managed to calculate the power and save the .mat file.My problem now is within HEAT, as I am struggling to adapt the example simulation to allow for transient heat simulations. Currently, I am able to use the FDTD Pabs data as the imported heat source, and I can simulate the temperature distribution as a result of this imported heat source. My problem now is with HEAT, as I'm having difficulty adapting the simulation example to allow transient heat simulations. At present, I'm able to run the simulation in steady-state mode, but my objective is to run the simulation in transient mode, so as to see the impact of the pulse duration on the temperature distribution evolution of my rectangle.ÂI've tried using the source shutter parameters on Heat's transient window to define a pulse, but I can't find any difference of temperature distribution when varying the pulse duration between 50nS and 500nS. I am unsure how to go about this as I do not want to set my own transient temperature/power boundary condition.ÂAny help or advice is greatly appreciated!Thanks -
January 30, 2024 at 7:53 am
Niki Papachristou
Forum ModeratorHi Ayoub,
Thank you for reaching out to us! Unfortunately, I can not think of an alternative other than creating a temperature boundary condition with bc mode transient.
Kind Regards,
Niki
January 30, 2024 at 9:08 am
ayoub.naoui
SubscriberHi Niki,Â
ÂThank you for your reply. The problem for me in using the bondary condition to create temperature is that the absorption in my rectangle is not uniform. Whereas using a power source in my rectangle gives an almost uniform heat distribution.ÂÂKind Regards,ÂAyoub
- The topic ‘Transient Heat Using FDTD Pabs as Import Heat Source’ is closed to new replies.
1307
