TAGGED: calculation-time, time-steps, timestep, transient
February 5, 2024 at 5:30 am
Mohamedramon77
Bbp_blocked -
February 5, 2024 at 12:18 pm
Forum ModeratorPlease repost the question.Â
February 5, 2024 at 12:25 pm
V.P
Ansys EmployeeHi Mohammed,
Can you describe your issue? I can only see the title (Transient fluid flow).
February 5, 2024 at 1:35 pm
Forum ModeratorOK, so you can calculate the time for the flow to cross one cell. As a starting time step aim for around 1/10 of that value. You then need enough time steps to reach the desired flow time of 20s.Â
I assume the 20s is a few residence times of the pipe and that you're monitoring something to determine whether you've reached equilibrium or whatever result you want to see evolve in the data.Â
February 5, 2024 at 1:50 pm
Forum ModeratorStaff are only able to communicate via the Forum.Â
Viewing 4 reply threads
- The topic ‘Transient fluid flow’ is closed to new replies.
