September 27, 2024 at 11:56 am
September 30, 2024 at 11:46 am
Lydia
Ansys EmployeeHi Ashish,
As it is stated in the documentation Chapter 4: Cyclic Symmetry Analyses (ansys.com)
"Transient analyses are not supported, with the exception noted in Static Cyclic Symmetry Analysis. "
As a workaround Cyclic symmetry for transient structural analysis can be inserted in the model by usining a Command Snippet with command CPCYC under “Transient” of “Tree Outline” of the model.
Example:
/prep7
cpcyc,all,,1,,90 !!! cylindrical coordinate system 1, location increments 90 degree
allsel,all /solu
September 30, 2024 at 1:29 pm
ashishkumar.gupta
SubscriberThank you for your response. So I am simulating radially loaded Deep Groove Ball Bearing with 9 balls. I have modeled only 1 ball = 40° out of 360°. So the code would change to:
cpcyc,all,,1,,40
allsel,all
1. Am I right?
2. Since this is radially loaded ball bearing, the load on each ball/sector (40°) would NOT be same. Then should I still proceed with Cyclic Symmetry or Normal Symmetry is preffered?
3. I will continue this modeling for FSI (MEch-Fluent). So the SAME symmetry needs to be modeled there for oil flow in Ansys Fluent?
4. Is it not possible to elminate the symmetry option and just apply some constraints on both the sides so I am only focusing on 40° model making my simulation analysis easier.
Thank you !
UPDATE: Transient structrural does not work with Cylic Symmetry even if we use the command snippet as u mentioned.
4597
1495
1386
1209
