November 2, 2020 at 5:23 pm
Luigi0
SubscriberHi,
I want to inject particles in my domain. The flow is laminar and two single injection are set. I expect that the trajectories should be rectilinear, but at the inlet the trajectories are deflected. What might could be the cause?
The inlet is a mass-flow inlet, I use Ansys 19.1, steady tacking dpm is used.
November 2, 2020 at 5:50 pmAmine Ben Hadj Ali
Ansys EmployeePlot velocity vectors and check pathlines of mass less particles. Particles with inertia might deviate from mean velocity direction.nNovember 2, 2020 at 8:39 pmLuigi0
SubscriberThe analysis is made with inert particles In order to plot mass less particles, should I re-run the analysis?nViewing 2 reply threads- The topic ‘Trajectories problem dpm’ is closed to new replies.
5179
1838
1387
1249
