October 23, 2017 at 9:33 am
prabu
SubscriberDear Sir/Madam,
I am solving a Open channel Multiphase(water and air) VOF problem. i am interested in plotting Total Force at a point vs time plots.The point i have chosen is on a wall perpendicular to the flow direction. Solution#2049647 guides to plot the same.The solution also suggest to sum both viscous and pressure force, irrespective of direction. I am also interested in adding dynamic force along with pressure and Viscous force. How shall i proceed writing CFF(Custom field function) for the same. After find this how to validate the results, is there a benchmark problem to validate the force plots.Kindly do the needful.
Thanks,
PRABU
9994435153
prabu.peterz@gmail.com
October 27, 2017 at 2:55 pm
Raef.Kobeissi
SubscriberHello PRABU,
Did you use the Monitor tool in fluent to capture the force vs time? Also, have you created a point at a certain coordinate in your domain to use in the Monitor facility? Please note, the above instructions are used in ANSYS Fluent. Cheers
November 20, 2017 at 7:31 am
prabu
SubscriberHello Raef,
Thanks for the response. I am using ANSYS Fluent only. I have created a point at a certain coordinate in my numerical domain to use in the Monitor facility.
But there is no clear cut force monitors. I think it has to be calculated from Pressures. How to achieve it. Thanks.Â
December 13, 2017 at 4:50 pm
maliuzair
Hello dears,
How can I get to the solution number mentioned in bold i.e. Solution#2049647. I have see many posts with solution numbers but I am totally new to the forum.Â
Regards
 Dear Sir/Madam,
Thanks,
PRABU
9994435153
- The topic ‘Total Force time series plot’ is closed to new replies.
6875
1343
1212
