January 30, 2022 at 7:45 pm
OROI
SubscriberHi
How i can plot total bending moment, there is min and max bending moment values but how make plot like bending moment total Y direction?
January 31, 2022 at 7:37 amVinayak Vipradas
To get a plot of Bending Moment values, you can insert the Total Shear-Moment Diagram available under Beam Results. Then define the Type as Directional Shear-Moment Diagram (VZ-UZ-MZ) and the Graphics Display as Y Bending Moment, to get the Bending Moment along Y-axis. You will need to define the Path by selecting the edge along which the result is to be obtained.
For further information on Shear-Moment Diagram, please refer to the following link:
Shear-Moment Diagram (ansys.com)
Regards Vinayak
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
January 31, 2022 at 5:11 pmOROI
SubscriberOk thanks, what if i want plot time dependent total bending moment. I can edit those min and max moment values with excel and make the plot that way, but can i get time dependent total moment directly somehow?
Viewing 2 reply threads- The topic ‘Total bending moment’ is closed to new replies.
4673
1565
1386
1230
