May 14, 2024 at 6:44 am
Azam Deen
SubscriberI've been trying to simulate wind turbine to plot the graph of power coefficient vs tip speed ratio by using MRF method. But the torque always converge to negative values. Was it due to the interface or need to refine the mesh.Â
May 17, 2024 at 1:33 pm
Federico
Ansys EmployeeHow did you set up your torque calculation? Are you sure that you have the rotation set up correctly?
- The topic ‘Torque of wind turbine’ is closed to new replies.
