Electronics
Electronics
Torque and Airgap Flux Density on ANSYS Motor-CAD
    • Adli Arisyi Suhaili
      How to get flux density graphs for all sequencial rotor degrees of rotation, for example from 0°, 10°, 20°, ...., 360° rotor rotation. Because when I rotate the radial cross section of rotor, the output (value and graph) will be the same as the initial radial cross section of rotor. I need to get a different value output.
    • HDLI
      Hello Adli,
            We might not get flux density for different flux density based on rotation angles in MotorCAD because it is machine design tool. You have to use Maxwell to do FEA for detailed information.
      HDLI
  • The topic ‘Torque and Airgap Flux Density on ANSYS Motor-CAD’ is closed to new replies.
