Topology optimization – Result with an asymmetrical design
    • Philippe CLECH
      Hello.
      In the case of a topology optimization study, with four loads according to the diagram below,
    • Hui Liu
      Is your model symmetric? meaning mesh, boundary conditions and loading.n
    • Philippe CLECH
      Hello Huiliu.n1°/ Concerning the mesh, here are the settings I have chosen:n_ General setting:n_ Method:n2°/Concerning the boundary condition and loading, here the definition apply:n_ the fixing hole being the fixed point (Valid for all 4 loads):n_ An inner side of the hanging ring. One side per direction and per load value:nLoad according to F3= 500NnLoad according to -F2 = 6000NnnLoad according to F2 = 6000NnnLoad according to F1= 1000Nnn3°/And concerning the topology optimization, here the definition apply:n_ Analysis settings : default valuesn_ Optimization region:nn_ Objective: Compliancen_ Response constraint: Massn_ Manufacture constraint: Member sizen_ Manufacture constraint: Pull Out DirectionnnIs that you see in these settings an explanation for the imbalance in the result of the topology optimization. nThanks in advance for your help.nBest regards?nPhilippe.n
      nIf you want a Symmetric geometry result, insert a Symmetry Manufacturing Constraint, or just optimize a half model with symmetry boundary conditions.n
    • Philippe CLECH
      Hello Petreoznewman.nWhen you say  insert a Symmetry Manufacturing Constraint, in my simulation, I have set up a manufacturing constraint according to the part's parting line with a Pull Out Direction like this:nnCould my problem come from the F3 effort which is not symmetrical (just oriented in one direction)?.
