Topology Optimisation ACT
    • HAEE
      I'm using Ansys 17.1 with the Topology Optimisation ACT extension. I have been having some problems in getting it to work.
      1) Linking Static structural Solution to topology Optimisation Set-up
      All the resources I can find online suggest this is crucial, however i cant seem to do this on Workbench.
      As im using an act extension, i cant create the link by "transfer to new" option in the static cstructural set-up.
      2. Also I wanted to ask about the capability of the topology optimisation extension I'm using. Does it support design dependent pressure loads? I cant seem to get it to work.
      Any references or advice would be great
      Thanks.
    • Sandeep Medikonda
      Please try to upgrade to the latest version.
      Topology optimization is built into the code and has undergone numerous changes since v17.2
      Relevant Discussion 1
      Relevant Discussion 2
      Relevant Discussion 3
      Relevant Discussion 4
      Unless until specified in the manual. All loads should be supported.
      How to access Online Help
      Sandeep
      Guidelines on the S.C
  • The topic ‘Topology Optimisation ACT’ is closed to new replies.
