July 2, 2024 at 1:42 pm
ngocminh2532003
SubscriberHello,
I am doing a MEMS model simulation on Ansys, I have done the stimulation but the result is far from the calculation, I don't know whether I did it correctly or not. Can somebody help me to check my simulation?
Thank you
Minh -
July 4, 2024 at 2:39 pm
Ashish Khemka
Forum ModeratorHi,
Can you please share the details of the setup and what you are expecting here? It will become easier for the forum members to comment.
Ashish Khemka
July 17, 2024 at 3:07 pm
ngocminh2532003
SubscriberÂ
Sorry for my delay, I had to pause my project due to health problem.
In my simulation, I set up a force of 413uN and the deformation along the X axis is 9.8125um (my expectation is about 20um), the deviation increases when the setup force becomes larger. Below are some details of my simulation.
Regards,Â
MinhÂ
July 17, 2024 at 3:14 pm
Ashish Khemka
Forum ModeratorHi Minh,
I hope you are in good health now and thanks for posting the details. Lower value of deformation in x-direction than expected indicates either a larger resistance to motion in that direction or lower force application. It may be required to look into the model which Ansys employees cannot do.
By the way what is the contact defined over here?
If you can share details of contact then it may help to comment further.
Ashish Khemka
July 17, 2024 at 4:30 pm
July 18, 2024 at 1:54 am
Ashish Khemka
Forum ModeratorHi,
Can you try turning off the small sliding? For contact detection try using nodal projected normal from contact. Please see if these changes help.
Ashish Khemka
July 18, 2024 at 5:47 am
July 19, 2024 at 12:29 pm
Ashish Khemka
Forum ModeratorHi,
What you can do in above scenario is to apply the displacement instead of force and mesaure the force reaction on the displacement boundary condition.
Ashish Khemka
July 20, 2024 at 1:09 am
ngocminh2532003
SubscriberHi,
When I did that the result remained unchanged, the measured reaction force was greatly higher than expected. Do you have any other suggestions for my simulation?
Minh -
July 22, 2024 at 9:57 am
Ashish Khemka
Forum ModeratorHi,
It would be difficult to comment without looking into the model. Please wait for other forum members to chime in.
Ashish Khemka
- The topic ‘Too small deformation’ is closed to new replies.
5654
1885
1404
1303
