September 13, 2024 at 1:20 pm
ciciola.2027298
SubscriberHi everyone,
I'm meshing a 3D complex geometry in Ansys Fluent Meshing. I applied local sizing, setting the face size to 0.002, and I imposed the first height of the boundary layer at a value of 0.0007. So, I expected the Aspect Ratio to be around 2 or 3. However, after generating the volume mesh, I obtained an Aspect Ratio of the surface mesh of over 20,000, and the Aspect Ratio of the volume mesh is around 100. Orthogonality and skewness are approximately 0.3 and 0.6, respectively.
Why is my Aspect Ratio so high?
September 13, 2024 at 1:34 pm
Forum ModeratorDid you set the whole, and all face size at 0.002? Also, if you have any proximity/curvature functions active you could have smaller/larger surface facets due to the geometry. If you plot the poor cells where are they?
September 23, 2024 at 4:06 pm
ciciola.2027298
Subscriberthe cells with highest aspect ratio are near the geometry, a lot of them are in the boundary layer (I'm sorry i can't show you any images) and this is understandable. But, I can't explain the high value of aspect ratio and, also, the high value of Skewness (it's over 1.2)
September 24, 2024 at 8:52 am
Forum ModeratorSkew can't exceed 1.0 as it's 0 (perfect) to 1.0 (flat), so please check.Â
Re the aspect ratio. Think what the purpose of a boundary layer mesh is. So, I'd expect a high aspect ratio. This may be acceptable, but assumes the flow values don't change much (and do so slowly) along the inflated surface.Â
September 24, 2024 at 1:10 pm
September 24, 2024 at 1:12 pm
ciciola.2027298
SubscriberIt happens only when I use Poly-hexcore cells, not when I use tetrahedral, but in the latter case, Fluent generates too much cells
September 24, 2024 at 1:18 pm
Forum ModeratorHave you got highly curved surfaces either in close proximity or that are poorly resolved? That looks like a poly cell (possibly poly-prism) has got turned inside out. Â
September 24, 2024 at 1:46 pm
ciciola.2027298
SubscriberYes, the geometry is complex (It's the upper part of a motorbike). How can I find and fix the problem?
