TAGGED: -Ansys-Maxwell-electronics, electrical, resistance
February 1, 2023 at 1:01 pm
Sidhartha Reddy Erla
Subscriberunable to find any tutorials online for the analysis related to "finding the resistance offered by a material" and to find the " dielectric break down strength of a material".
suggest me if there are any tutorials.
February 6, 2023 at 11:45 am
Praneeth
Ansys EmployeeHi Sidhartha,
Thank you for reaching out to us and we appreciate your patience.
Kindly let us know which Ansys tool and the version that you are using to help us serve you better. Also, some information about your simulation model and the goal is greatly appreciated. Add category tags as well which can further help us provide response quickly.
Best regards,
Praneeth. -
February 6, 2023 at 12:07 pm
SubscriberHello
Praneeth,
thank you for the response.Regarding ” information about my simulation”
Q 1
I have attached a picture of the model which consists of electrodes.
there is a gap i between the electrodes which is filled with polymer composite.
I want to find out the “dielectric break down strength”(voltage at which the material disintegrates)Q2
I also want to find the resistance offered by any material when it is placed in a cricuit.
”Ansys tools”
I have latest available student versions of ANSYS and ANSYS ELECTRICAL.
As per my research in internet
simulation to find the resistance is done with “electrical” in “ansys Work bench”
and
simulation to find the dielectric break down strength is done in ANSYS MAXWELL
I AM NEW TO THESE TWO PLATFORMS.
green rod like structures are electrodes.
rest of the part in blue color polymer composite material.
February 13, 2023 at 9:11 am
GLUO
Ansys EmployeeHello,
Maxwell can simulate the E field and charge distribution. I think you have to find out the breakdown voltage of this material from data sheet, then use Maxwell to simulate your design model to see which location reaches this voltage first and decide what is the breakdown voltage for this design. Maxwell can also calculate the resistance of a conductor in your design.
GLUO
March 21, 2023 at 2:35 pm
SubscriberHello,
Thank you for the reply
I have never used Ansys Maxwell before. Can you please provide me tutorial sources or link where i can learn the Ansys Maxwell from.
- The topic ‘To find resistance and Dielectric break down strength of a composite material.’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3892
1414
1241
1118
1015
