March 5, 2020 at 12:12 pm
DanEm
SubscriberHello,
I tried a thermal stress analysis in Workbench but I have some problems with the time steps. The beginning stept is 0s and the max step is 20 s but ANSYS says that this a problem which leads to the unability to perform my simulation. I added a screenshot which shows the steps used.
Can someone explain me what I need to enter there? And moreover, what is the reason for this issue?
Wishes,
Dan
March 5, 2020 at 12:53 pm
peteroznewman
SubscriberThe initial time step must be larger than the minimum time step.
Try using 5 s for Initial, 0.5 s for minimum and 20 s for maximum.
March 15, 2020 at 8:28 am
DanEm
SubscriberHi Peter,Â
thanks for your answer! I tried your time settings, but Ansys still says that there is something wrong. It marks the 20 s 5 and 0.5 is not marked yellow. I do not understand why this is happening now. I tried 6 and 30 s instead of 20 but this is marked as well. Can you explain me this?
March 15, 2020 at 6:45 pm
peteroznewman
SubscriberPlease reply and insert a screen snaphot image of the analysis settings.
March 29, 2020 at 2:17 pm
DanEm
Subscriber -
March 30, 2020 at 2:56 am
peteroznewman
SubscriberThe initial time must be greater than or equal to the minimum time step.
The End Time must be greater than or equal to the Maximum Time Step.
Try this.
End Time 20 s
Initial Time Step 1 s
Minimum Time Step 0.1 s. That way, the solver can reduce the time step if necessary.
Maximum Time Step 4 s. That way, you get more than 5 results on the way to the end time.
March 31, 2020 at 9:36 am
DanEm
SubscriberI have no "end time". I have Initial, min and max. How can I get this end time array?
March 31, 2020 at 12:50 pm
April 8, 2020 at 10:33 am
DanEm
SubscriberHi,
thanks, I found it. It has a completly other name in german. ANSYS simulates something now, but it doesn't make sense, so I need to look in the simulation again.
- The topic ‘Time step problems with thermal stress simulation’ is closed to new replies.
