April 10, 2020 at 12:25 pm
muneebvohra
SubscriberDear Sir
what is the basis for the initial time step formula? and what does it signifies? Can you explain it further? And what is the maximum or minimum time step? As far as I know, the time step is the difference between two consecutive time intervals. For instance, if the initial time =1s, and the time step is .001 then the system will do analysis at 1.001s. Therefore I am confused about the maximum or minimum time step and how it can impact our analysis?
Thanks
April 10, 2020 at 2:18 pm
Wenlong
Ansys EmployeeHi,
I assume you are talking about static or transient structural analysis. The initial, maximum, and minimum time step is referring to the substeps. A step can consist of several substeps, and if you define the initial step, max, and min substep size, your substep will start at the initial value, and varies within the min and max values. This is based on you have turned on "automatic time stepping" and the solver will adjust the substep size to optimize the simulation speed.
This website has a very detailed description of step and substep definitions:Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/wb_sim/ds_Steps_Substeps_Eq.html
This website has a guideline for integration step size (in other words, how to choose sub-step size):Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/wb_sim/ds_guidelines_int_time.html
Wenlong
Useful Links
- How to access Ansys Online Help Document
- How to show full resolution image
- How to use Google to search within Ansys Student Community
April 10, 2020 at 3:24 pm
muneebvohra
Subscriber I do not have the account number to sign up. Can you tell me how to get it?
April 10, 2020 at 8:02 pm
Wenlong
Ansys EmployeePlease see my attached "useful links"
- The topic ‘Time step’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3912
1414
1256
1118
1015
