Time derivative computation
    • Loïc Féréol
      Hi Ansys community,
      I want to compute a derivative using APDL. To be precise, I want to calculate the heating rate in post processing, i.e. the time derivative of Temperature. To do so, my idea is to use an Euler scheme using the temperature for a given time, the one before and the time step. Is there a way to do so (for an APDL beginner)?
      Thank you,
    • erik.kostson
      Hi
      One way of looking at this.
      Perhaps look at post26 commands DERIV and prvar or plvar.
      See the apdl command reference (in the help manual) for more info on these commands.
      All the best
      Erik
    • Chandra Sekaran
      Yes, Post26 operations as Erik points out are best for doing this in MAPDL.
    • Loïc Féréol
      Hi Erik and Chandra,
      Thank you for your answers. I'm working on this right away !
      Best,
      Loïc
    • erik.kostson
      A sample code that might help (variable 1 is time):
      /POST26
      nsol,2,2047,temp
      deriv,3,2,1
      plvar,3
    • Loïc Féréol
      First, thank you for your advices that helped me a lot. For the moment, I can calculate the heating rate for each node and display it. Is there a command to display the quantity calculated on all the domain for a given time step (just like the temperature) ? I did not find such a command in the manual.
      Best,
Viewing 5 reply threads
  • The topic ‘Time derivative computation’ is closed to new replies.
