June 11, 2019 at 3:59 am
arunsp453
SubscriberÂ
How to do time averaging of velocity field?
brief explanation.
i done the simulation for mixing of air and swirled air which are passing through central and annular pipe and i am looking for velocity field in outer domain.
yes i am getting velocity field but since the flow is turbulent, i expect velocity field is composition of mean and fluctuating velocity component.
so i would like to get time averaged velocity so the field is smooth.
should i consider the iterations once after the solution got converged? or is their any hint for my problem?
thank you
June 11, 2019 at 4:38 am
DrAmine
Ansys EmployeeI assume you are using standard RANS turbulence model and the velocity you see is the time dependent mean velocity without any turbulence dependent fluctuations. -
June 11, 2019 at 8:57 am
arunsp453
SubscriberYes i am using Reynolds stress model and i am just piloting velocity contours in theÂ
CFD post once after solution gets converges.... i want data of time averaged velocity. should i run the simulation in transient mode to get time averaged velocity or how it is so? -
June 11, 2019 at 9:26 am
Forum ModeratorNote: I've locked the other thread on this subject. Please don't post questions more than once in different places.Â
June 11, 2019 at 9:30 am
arunsp453
Subscriberi am sorry..
June 11, 2019 at 9:52 am
DrAmine
Ansys Employee To get transient averaged data you need to enable data sampling in Fluent or use a script in CFD-Post to do the transient average there if you forgot to do that in Fluent.
June 16, 2019 at 5:10 am
arunsp453
Subscriberthank you, i enabled the data sampling for time statistics.Â
what this ''user memory location'' and ''node memory location''.? are these options help to do time averaging?Â
June 17, 2019 at 4:51 am
DrAmine
Ansys EmployeeYes possible by UDF. Transient data sampling is built-in and you do not require user defined memory locations to do sampling. -
June 17, 2019 at 8:22 am
arunsp453
SubscriberThank you, abenhadj
June 17, 2019 at 11:19 am
DrAmine
Ansys EmployeePlease mark this as is Solved.
- The topic ‘Time averaged velocity’ is closed to new replies.
3492
1057
1051
965
942
