time average for unsteady case
    • zels496
      I am simulation a flow over a porous square cylinder and I am interested in calculating the time average values for p and u over a period of time, also how can I draw time-averaged pressure and velocity contours?
    • Keyur Kanade
      please create custom field function for variable you want.
      use data sampling for time average values.
      following links may help you.
      /forum/forums/topic/time-averaging-over-different-time-periods/
      https://www.youtube.com/watch?v=9ebSH84vIWo
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • zels496
      here is a way using  Data Sampling for Time Statistics option in fluent I think and it is easier ??
      I am not quite sure but I have found on fluent
      https://www.sharcnet.ca/Software/Fluent6/html/ug/node1045.htm
    • Keyur Kanade
      go to solution - run calculation - advanced - options - data sampling
    • zels496
      how to define the time for the start and end of time sample?
      if I want to start from 100 sec to 200 sec, not from the start of simulation time
    • Keyur Kanade
      run till 100 sec.
      then make data sampling on.
    • zels496
      how to get the time-averaged results, it can be seen also from cfd post ?
    • zels496
      what is the sampling interval ??
    • Keyur Kanade
      sampling interval is the interval where variable values will be taken into sampling considerations.
      please check the help manual for more details.
    • zels496
      if I want to average from 100s to 200 sec should I set the sampling interval to 100 sec?
      I have tried sampling interval 1 but the average was equal to the last time step result
      it is not clear for  me how to set a value for it even after checking fluent tutorials
    • Keyur Kanade
      sampling interval is at what time step you want to take sample.
      i recommend you to go through help as mentioned above.
Viewing 10 reply threads
  • The topic ‘time average for unsteady case’ is closed to new replies.
