September 9, 2024 at 12:30 am
pdsamuel
SubscriberHello, I have been trying to use tiebreak contact with the 20 noded Hexahedral solid element (ELFORM 23). When I select the surfaces using the segment set approach- it keeps giving me an error that certain master, slave surfaces have not been not found. Because this didn't work, I then tried defining tiebreak contact using the PARTSET. But, the nodes on the middle of the edges don't get selected and only the nodes on the corners are tied. I strongly prefer to use the segment set selection of tiebreak surfaces, and need to know to how to execute this. Can anyone share some insight on this? Thanks
September 9, 2024 at 8:44 am
ErKo
Ansys EmployeeHi
I would suggest to post it in the correct/dedicated LS-Dyna forum (this here is mechanical).
All the best
Erik
4597
1500
1386
1209
