LS Dyna
LS Dyna
    • 2198215399
      For *CONTACT_TIEBREAK_SURFACE_TO_SURFACE what is the formula for the bond between the two in this contact algorithm?
    • Pedram Samadian
      The *CONTACT_TIEBREAK_SURFACE_TO_SURFACE keyword in LS-DYNA lets you define a bond between two surfaces, which can break under certain conditions and turn into a regular sliding contact after failure. This uses penalty-based contact formulations. In this contact algorithm, the bond between surfaces fails when:
      NFLS = Tensile failure stress
      SFLS = Shear failure stress
      = Applied normal stress
      = Applied shear stress
      For further information, please check the contact section in the LS-DYNA User Manual Vol. 1 (LSDYNA Manuals).
      I hope this answers your question.
      Thanks,
      Pedram
