November 29, 2021 at 1:48 pm
Wolfgang Geist
Subscriber -
November 29, 2021 at 2:04 pm
Charudatta Bandgar
SubscriberHello Ghost1246
Let me check with the team, if any such change is made.
Regards.
November 30, 2021 at 6:29 am
Charudatta Bandgar
The feature is not removed with the new release as far as I know, what could be happening in this situation is probably a result of the way Windows stores the value of the preview handler file. It can only store 1 value at a time, so usually it has the older version location stored. installing an update will no overwrite this. If the old version is then uninstalled, there will be not link to the thumbnail handler for the new installation. What I would suggest you is, if it is possible for you, uninstall the versions and install the latest SC version first.Â
Regards.
December 3, 2021 at 1:40 pm
Roberto
SubscriberHello Charudatta Bandgar
Once in the old versions of SpaceClaim before 2021 it was possible to reset the preview value through the ThumbnailHandler.dll file, is it no longer possible to do this with the new versions?
Regards
December 3, 2021 at 2:40 pm
Charudatta Bandgar
SubscriberRoberto I am not sure. Let me check.
Regards
December 3, 2021 at 3:08 pm
Charudatta Bandgar
SubscriberRoberto
One thing worth trying is to navigate to C:Program FilesSpaceClaim 2021 R1 and locate "thumbnailprovider.dll". Right click and go to Properties > Security . Click Edit, then select each group in the list and activate the Allow check box for Full Control. Repeat this for every group, then click Apply and OK. See if that can be possible.
December 3, 2021 at 3:18 pm
Roberto
SubscriberCharudatta Bandgar Hello Should this be done before installing a new version? to make the preview work even if a user has several versions installed I Attached video? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
December 7, 2021 at 1:24 pm
Charudatta Bandgar
SubscriberRoberto It should be possible after installing as well.Â
- The topic ‘Thumbnail Views in Explorer for SpaceClaim’ is closed to new replies.
5734
