Threaded faces
    • gambra77
      Hi everyone,
      Im trying to analyze a bolted union and i need to set de face but a yellowed part appears. What does thickness refer to? The diameter? The pitch?
      Other cuestion is, if there is not nut do i need to aply pretension or can i set a different situation to apply compressive force
    • harshvardhan.negi
      Looking at the screenshot, the tornillo_d8_L25.3\OuterThread geometry is a surface type germetry. Since the analysis is 3D, it is asking for the thickness of the shell elements that will be created for this geometry.
      I think you may have to revisit the CAD model and see if this arrangement is exactly what you want.
      You can apply pretension to a bolt without nut. Make sure that the threaded part of the bolt has proper connections with the clamp.
      I hope this helps.
      Harshvardhan
      Ansys Help
      Ansys Learning Forum (Rules & Guidelines)
