3D Design
3D Design
this error: operation would result in non- manifold bodies appear. anybody know what to do?
    • fatimahamri97
    • Vigneswaran Sridharan
      Hi This error message appears when we try to do an operation that affects one dimension that is close to the maximum dimensions allowed in the model and/or if we create volume bodies without thickness after doing a slice.
      This is usually a tolerance issue for slightly bumpy surfaces. If the slice is close to the limits, you can enable the large model option or you can modify this dimension avoiding surface in the domain limits.
      Due to tolerance limitations, it is also possible that the slice creates volume bodies without thickness. If possible, slice at a slightly different position and make sure that the existing surfaces at the slice position are perfectly planar.
      Vigneswaran
    • lidianne.pinto
      Hello fatimahamri97, Did you able to solve the problem? I'm having a similar error
  • The topic ‘this error: operation would result in non- manifold bodies appear. anybody know what to do?’ is closed to new replies.
