September 17, 2022 at 4:49 pm
David_SY
SubscriberHi, I am trying to mesh a 900mm diameter cylinderical thin film with 0.1um thickness.
I tried different mesh elements and sizes with some applicable option to imporve the mesh quality. However, still the quality is not good.
Any tips for meshing the thin film?
Thanks.
September 19, 2022 at 4:26 am
Keyur Kanade
Ansys EmployeeI am assuming you have boundary layer/inflation/prism layers on cylindrical wall. You will need to reduce surface mesh size. If you use coarser surface mesh size on cylindrical surfacw with so small inflation then it may give bad elements. So please refine surface mesh further.Â
The min orthogonal quality should be above 0.1 to proceed to solver. If it is less than 0.1 then please improve the mesh.ÂFirst check the locations of the bad elements. Please see following video for the same.ÂÂhttps://www.youtube.com/watch?v=ZDADSSN8hOsÂOnce you have locations, please check if you can improve mesh using different mesh sizing. Please see following video.ÂÂhttps://www.youtube.com/watch?v=w4q6q8nKF3UÂYou can see more information about sizing at following link.Âhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/wb_msh/msh_Use_Adv_SF.html?q=sizing -
September 20, 2022 at 10:33 am
Forum ModeratorTo confirm, you have a 900mm diameter pipe and want a 0.1micron near wall cell height? What size is the wall surface mesh?Â
September 20, 2022 at 6:33 pm
David_SY
SubscriberActually a 900 mm diameter cylindrical reactor with a 0.1 mm thickness.Â
I generated a mesh with good quality, it has a lot of elements, though.
Anyway, I figured it out. Thanks for your help!
September 21, 2022 at 9:16 am
Forum ModeratorGood to hear. When dealing with VERY small sections it can be easier to build geometry in "units" and scale in the solver. I've also used anisotropic adaption to refine a mesh in a narrow gap when putting more than 2 cells in broke the CAD tolerances.Â
- The topic ‘Thin Film Meshing’ is closed to new replies.
5824
