July 7, 2025 at 2:12 am
zhangxinyue
Subscriber.I encountered an issue while using the SpaceClaim module in ANSYS 2024 R1. Specifically, I imported aÂ
.stl
skull model for steady-state thermal analysis. However, after converting the STL file into a solid, the model's thickness was unexpectedly altered and did not retain its original geometric dimensions.Since my analysis relies on accurate thickness data for thermal conduction simulation, this alteration significantly affects the validity of the results.
Viewing 0 reply threads
Ansys Innovation Space
1057
1051
918
896
