April 29, 2024 at 4:35 pm
Foo Sin Khai
This is my combustion chamber wall temperature contour. Now, i want to extract the heat convert to electric by using thermal-electric simulation.Â
1) I need to transfer the contour data to another surface. I need to some how map the contour of the wall temperature to the another surface so that i can obtain the temperature of the hot side. Somehow i need to transfer contour data from fluent to mechanical. (pic below can describe)
April 29, 2024 at 4:43 pm
Foo Sin Khai
Subscriberso my question: is there any alternatives i can do this so that i can mapped the temperature contour of the combustion chamber wall to the thermoelectric generator inner surface which is the hot side of thermoelectric generator or you have better suggestion or way to this simulation. Very appreciated your advice.
April 30, 2024 at 7:08 am
ErKo
Ansys EmployeeÂ
Hi
You should be able to drag and drop from a Fluent system (Solution cell) to the Thermal Electric System (Set up cell) say in 2023 R2.
In that system you can then add: Imported Load (Fluids Results File) and a temperature load import.
See here for this workflow - it is for steady state but should be similar for thermal electric.
Otherwise external data can be used.
Erik
April 30, 2024 at 7:22 am
April 30, 2024 at 8:35 am
Foo Sin Khai
Subscriberi think i want go with external data approach. can you teach me how to export data file in csv in fluent because i couldn't make it even with the video tutorial on youtube.
April 30, 2024 at 9:03 am
ErKo
Ansys EmployeeHi
This is fluent related.
See/post the fluids forum.
This post might also be of help:
/forum/forums/topic/how-to-export-temperature-file-in-just-one-cell-zone/
All the best
Erik
May 2, 2024 at 3:57 am
May 2, 2024 at 7:40 am
Foo Sin Khai
SubscriberThis is the geometry and the setup including the engineering data setup. Can you help me to see whether where the issue come from? Because like i mentioned earlier the heat absorbed and released is the same. I would expect there is difference between this two value. And my final aim is to find the electrical power generated. Do you have any suggestion on how to calculate the electrical power generated on converted from this TEG based on my model here?
May 3, 2024 at 11:13 am
Foo Sin Khai
SubscriberHi there, anyone can help with the problem here?
May 9, 2024 at 5:49 am
rixiu
SubscriberHi, Erik. Do you have any suggestion how to solve the problem here?
- The topic ‘Thermoelectric Extraction from Simulated Combustion Chamber Wall from Fluent’ is closed to new replies.
4607
1510
1386
1209
