October 18, 2023 at 9:55 am
Nabila Sulaiman
SubscriberHi. Anyone works on radiation model in Ansys Fluent?
Currently, I am working on Evacuated Tube Solar Collector for thermal collector and stuck in modelling the heat transfer within it. I have been trying a couple of times to model it by S2S and DO model but unfortunately it was not exhibited the actual flow of heat transfer as I did not know on how to insert and apply the transmissivity and emissivity through it.
October 20, 2023 at 10:23 am
C N
Ansys EmployeeHello Nabila,
I recommend you to set the boundary conditions at wall as mixed under thermal conditions and set the appropriate external emissivity. Depending on whether it is gray body or non gray body , opaque or semi transparent go to radiation option and set the diffuse fraction and if it is semi transparent please set the internal emissivity.
For all translucent bodies, the sum of reflectivity , emissivity and transmissivity is equal to 1.
So accordingly if you know the transmissivity and reflectivity values , you can set the emissivity .Â
For further understanding on how to create appropriate boundary conditions and cell zones for DO modelling . I am attaching a link for your reference.
5.3.6. Discrete Ordinates (DO) Radiation Model Theory (ansys.com)
Please referÂ
5.3.6.7. Cell Zone and Boundary Condition Treatment at Semi-Transparent Walls
This will help you in understanding how ansys fluent assumes the transmissivity value for semi transparent case. Assuming your case involves semitransparent bodies.
As a workaround you can also enter specific profile of transmissivity through udf or expressions and perform the calculations.
I hope this helps you in your simulation.
Thanks,
October 20, 2023 at 2:54 pm
Nabila Sulaiman
SubscriberThank you C N for responding to my question. I will try to do it first and update you the result. ?
- The topic ‘Thermal Radiation Model’ is closed to new replies.
5649
1885
1404
1303
