November 20, 2024 at 6:15 pm
cb.en.p2edn23001
SubscriberTable1. Mesh Sensitivity Test
Element
edge size
Square
cylinder
Hexagon
cylinder
Octagon
cylinder
Circular
cylinder
0.2 344.248 343.3291 342.2664 345.8729
0.1 343.8929 343.2161 342.0569 345.7442
0.05 343.7064 342.6477 341.3922 345.5785
0.03 343.6591 342.538 341.1802 345.5469
0.025 343.6472 342.5136 341.1242 345.5315
0.02 343.6339 342.4941 341.1 345.5225how to give the BC and how to create the condition of multiphase can anyone give an idea and for give any thermal flux value
November 25, 2024 at 3:06 pm
dlooman
Ansys EmployeeIf you have enough cells and the heat load is the same on each cell then you can specify adiabatic boundary conditions on the top and bottom surface. The adiabatic condition is obtained by not specifying any constraint on surface. It's less clear what the boundary condition on the vertical surfaces could be. The only alternative to adiabatic is flux normal which is obtained by coupling temperature on that surface and that doesn't correct because that would make the temperature constant over the entire surface. If you had included a quarter of the cell to the right of the indicated domain you could apply periodic boundary conditions to the right and left surface. A periodic boundary condition forces the temperature to be the same at the left and right boundaries and is obtained by coupling temperature across the model. You describe the analysis as thermal conductivity, but frequently motion of the fluid is important and would require a CFD analysis.
November 25, 2024 at 4:48 pm
cb.en.p2edn23001
Subscriberhow can I give the BC in the ansys fluent and how do I get this type of result. I have tried the steady-state thermal analysis from Ansys and am getting different contours.Â
Can you kindly guide me for this problem and also I'm giving the paper linkNumerical modeling of temperature-dependent effective thermal conductivity of two-phase porous system using square and circular geometries
November 26, 2024 at 5:46 pm
dlooman
Ansys EmployeeDifferent from what? Each other? Different from the paper? I couldn't access the link. Create another post for the Fluent question. We on the mechanical side can't answer questions about Fluent.
November 26, 2024 at 6:30 pm
cb.en.p2edn23001
SubscriberÂ
I want to run this simulation but don’t know how to create the setup file in fluent, and how to give the BC, I have tried in the ansys steady-state thermal ansys tool but it was correct or not that I don’t know, or else I’m trying in fluent, kindly give some idea how to run this simulation in fluent, and provide some both mechanical and fluent idea so it can help me a lot. Research Paper link (https://drive.google.com/file/d/1qw59rboaOBRLb9R1x9TFtoCV2bcskAd6/view?usp=sharing) Two-phase thermal conductivity
November 27, 2024 at 3:33 pm
dlooman
Ansys EmployeeCreate a new post for Fluent analysis
6269
