July 28, 2021 at 9:42 am
Lukas8778
SubscriberHey there,
I'm trying to conduct a 3D thermal analysis of a PMSM similar as in one of your youtube tutorials with a coupling from maxwell to mechancial.
July 29, 2021 at 11:12 amNavya Chode
Forum ModeratorHi @Lukas8778 If you copy-pasted the design you should not be facing the issue. In fact, I never faced this issue.
I suggest you check if you have hidden any object in maxwell before coying into Icepak.
Regards Navya
October 18, 2021 at 4:44 pmNikhil Tamhankar
Ansys EmployeeHi @Lukas8778 Do you have a 3D component in your Maxwell design ? You might have to right click on that component, Edit Component which will open in a separate project in AEDT. Then press Ctrl A + Ctrl C to copy the geometry + materials and use Ctrl V to paste the geometry in Icepak or Mechanical (Thermal) in AEDT. Then try again to run the solution. The geometry from Maxwell should be identical and in exact same location as that of Maxwell to for the EM loss mapping to work.
May 17, 2023 at 10:41 pmAbdelkrim Bouzid
SubscriberHello I hope you doing well
I have the same problem and I copied and pasted, plus "failed to get presolved data"
And the last one when I copied the geometry the sheets become unassigned.
Those are my problemsÂ
And thank youÂ
Viewing 3 reply threads- The topic ‘Thermal Analysis of a PMSM’ is closed to new replies.
