TAGGED: input-parameter, Moderator Discovery Geometry, move
March 26, 2024 at 8:50 am
JUGYEONG SHIN
SubscriberHello all,
I have a questions about parameter of Discovery.
How can I define parameter for the specific angle?
Up to the 2021 version, when the Move function was used, the parameter for the angle could be defined. There was also an example video of the Ansys.
However, recently, if I activate the move function and select the angle, I can't see the parameter button, and if I select the direction, I can see the parameter button.
I want to compare the results according to the angle change of the body.
I want to know if the angle can no longer be defined as a parameter. And if it can be defined, I would like you to show me how or an example.
Best Regards,
Jugyeong Shin
March 27, 2024 at 8:21 am
March 28, 2024 at 1:03 am
JUGYEONG SHIN
Subscriber -
March 28, 2024 at 10:49 am
March 29, 2024 at 12:15 am
JUGYEONG SHIN
SubscriberÂ
Hello Atharv,
Thank you for your answer.
I did same as you did(select single angular direction and then rotate) but the Parameter button didn’t appear as shown in the picture below.
(I did it on my collague’s computer, but there was no difference.)
Is there any option to turn on to use parameter?
Best Regards,
Jugyeong Shin
March 29, 2024 at 5:24 am
Atharv Joshi
Forum ModeratorHi Jugyeong,Â
Can you try installing the Service Pack and check if it solves the problem?
Thanks and Regards
Atharv -
April 1, 2024 at 4:09 am
JUGYEONG SHIN
SubscriberHello Atharv,
I tried to install the Service Pack(2024R1.02), but the problem is not solved.
Is there another way to solve this problem?
Best Regards,
Jugyeong Shin
- The topic ‘The way to create parameter for the angle.’ is closed to new replies.
5934
1307
