October 11, 2021 at 7:01 am
唐靖博
SubscriberFor the pressure-based solver Tref is 298.15K except for PDF models. For the density-based solver Tref is 0K except when modeling species transport with reactions. But I found that the enthalpy of oxygen is not zero at the temperature of 298.15K when using pressure-based solver.
October 11, 2021 at 8:45 amAmine Ben Hadj Ali
Ansys EmployeeIf species model is active you will need to check the value of formation enthalpy: if this is not zero you will have a non zero enthalpy.
October 11, 2021 at 9:32 am唐靖博
SubscriberOxygen is an elementary substance whose standard enthalpy of formation is zero.
October 11, 2021 at 2:28 pmAmine Ben Hadj Ali
Ansys EmployeeThen please add a screenshot of the Flux Report for Heat and the inlet boundary.
Viewing 3 reply threads- The topic ‘The value used for reference temperature in the sensible enthalpy calculation’ is closed to new replies.
Innovation SpaceTrending discussions- JACOBI Convergence Issue in ANSYS AQWA
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
Top Contributors-
4597
1495
1386
1209
