The Top Rebars remain unmeshed.
    • a.m.aanikce
      I am following a tutorial on ANSYS for RCC Beam.
      https://www.youtube.com/watch?v=oOQ4_jIjHkE
      But the problem is that the top rebars are behaving as an independent body and is not showing any sign of meshing.
      As per the tutorial the rebar should behave as following:
    • Aniket
      Do you have same mesh size on rebars and concrete? n-AniketnHow to access Ansys Online Help Documentnn
    • a.m.aanikce
      Yes.n
    • Aniket
      so are you sure that the nodes are being bonded with the tolerance that you are using (0.1)? Does it help having larger tolerance? I will also recommend cutting the solid and having a shared topo only for solids excluding beams so you have a node at every location in the solid where you have beam nodes.n-AniketnHow to access Ansys Online Help Documentn
    • Keyur Kanade
      Thanks Aniket!n
Viewing 4 reply threads
  • The topic ‘The Top Rebars remain unmeshed.’ is closed to new replies.
