December 1, 2019 at 2:38 am
vsmlingam
Hi friends - I am working in the analysis of hydrodynamic analysis of dolphin - In this trail simulation - I set a boundary condition of dolphin swim in a Pool - I set all surrounding as free wall - open is at 1 atm relative pressure - Also i assign a local co-ordinate system fo Dolphin - There is no error in Ansys cfx - but i got an error at solving a file - the error i got isÂ
"Update failed for the Solution component in Fluid Flow (CFX). The solver failed with a non-zero exit code of : 2"
Kindly help me to resolve the issuse
December 1, 2019 at 1:23 pm
vsmlingam
Subscriberhttps://youtu.be/C47PYE45o_s
ANSYS CFX - Hydrodynamic simulation Error - "The solver failed with a non-zero exit code of : 2"
I attach a video file by the above link - regards "The solver failed with a non - zero exit code of : 2
This is my first case - the Robotic dolphin swim inside a water tank - based on that i assign a boundary condition - there is no error in CFX - Pre setup - but while comes to solver I got a "Non-Zero Exit code of 2"
Kindly give me your valuable suggestion for resolve this issuse
December 1, 2019 at 1:31 pm
vsmlingam
Subscriberhttps://youtu.be/svbREzzNGVg
I attach a video file by the above link - regards "The solver failed with a non - zero exit code of 2
This is my first case - the Robotic dolphin swim in a sea against waves - based on that I assign a boundary condition - there is no error in CFX - Pre setup - but while comes to solver I got a "Non-Zero Exit code of 2"
Kindly give me your valuable suggestion for resolve this issue
December 1, 2019 at 1:42 pm
vsmlingam
SubscriberI also attach my Dolphin IGES file with the below link - Kindly help me for the above problems
https://drive.google.com/open?id=1wspkbJvTANhI6B8ENczsIQtiHPTJBldw
December 2, 2019 at 6:16 am
DrAmine
Ansys EmployeeWhat about the out file of CFX? Any hints there? -
December 2, 2019 at 5:59 pm
vsmlingam
SubscriberDear sir,
Sorry for my mistake, Due to more memory Ansys file i can't upload it - But i considered two case
1. dolphin as a solid domain & inside a Swing tank fluid domain with a moving velocity about local co-ordinate Coord 1 -Â
2. Dolphin as a solid domain inside a sea - fluid domain with a moving velocity about local coordinate 1
In both cases - No error is shown in CFX Pre - Boundry set up - but when I click start run - it showsÂ
December 2, 2019 at 6:16 pm
vsmlingam
SubscriberHere IÂ attach my second case cfx file, sir :Â https://drive.google.com/open?id=1MRTXa9JMohLcFjryjStFXodhTZWnPKfq
December 3, 2019 at 4:28 pm
DrAmine
Ansys EmployeeJust tell us what you have in the outfile as additional message. Ansys staff do not look into any attachments -
December 3, 2019 at 4:29 pm
DrAmine
Ansys EmployeeTry to move the dolphin instead of the fluid domain
- The topic ‘The solver failed with a non-zero exit code of : 2’ is closed to new replies.
5794
