October 18, 2024 at 11:44 am
1617836513
SubscriberI set up the settings for restart in the static structure as in figure 1, after that I want to continue the calculation after clicking on the STOP button (without making any changes to the model in the meantime), and I chose a sub-step before the last step of the convergence calculation. But it appears that the restart point is invalid, why is this?
October 21, 2024 at 10:48 am
harshvardhan.negi
Ansys EmployeeHi,
There can be multiple reasons for the solver to remove/modify restart points.
You can check out the following links about restart points in Ansys and see if they have something that can help you out:
18.5. Using Solution Restarts
16.1.4. Restart Analysis
I hope this helps.
Harshvardhan
1890
1419
1304
