March 19, 2024 at 6:07 am
zouxie
SubscriberDear Sensei.
In the far field setting, 'Assume structure is periodic' is checked and the appropriate x, y, z periods are set. I will be able to get the far-field reflection angle close to the expected result. Otherwise, the results obtained will be 1.5° off from what is expected.
I would like to know: why I get the expected far-field reflection angle only after phase correction. Looking forward to your reply. Thank you
I've studied this one.
March 19, 2024 at 6:10 am
March 19, 2024 at 8:41 pm
Guilin Sun
Ansys EmployeeThank you for finding the solution!
As the website says, "assume periodic" is an approximation, since the simulation with plane wave +periodic BCs assumes infinite periodicity. When it is approxiated to be finite number of periods for farfield projection, a window function is added. The result is similar to convolution of the simulated periodic fields and the window function.
March 20, 2024 at 2:34 am
zouxie
SubscriberThanks for your reply.
Maybe I can understand your reply like this? For more accurate far-field results, the finite number of periods and 'Assume structure is periodic' are used in pairs.
March 20, 2024 at 3:35 pm
Guilin Sun
Ansys EmployeeIn your case ther unit cell (one period) contains several teeth with different size, right? using grating analysis gets the result from infinite numbber of periods. If you want results from finite number of periods, yes you have to use "assume periodic" to approximate it.
March 21, 2024 at 1:24 am
zouxie
SubscriberOk, thank you for your patience in replying. My problem has been solved.
Have a good day~~
- The topic ‘The role of the assume periodic option in far-field projections’ is closed to new replies.
5649
1885
1404
1303
