May 14, 2019 at 7:23 pm
Serdal
Subscriberhi all
I am taking the error in my ANSYS 2019 R1. After the axial loading to my volume, I want to display the stress, strain results but I take warning which is 'The requested S data is not avaliable. The PLNSOL command is ignored'. Then, if I go to folder which is saved of Ansys files, I observe err folder. The err folder contains messages which are ' The EPLOT command cannot be executed. The selected elements cannot be displayed by PowerGraphics. To correct this situation, select different elements or turn off PowerGraphics.' Then I shut PowerGraphics but the result is still same. My ansys programme is Student version from Ansys products. By the way my shape is created in Ansys Mechanical apdl-2015, I want to load in my Ansys-2019 to this volume but it is not. I hope I could explain my situation
Thanks for any help
Serdal
May 15, 2019 at 1:46 am
Sandeep Medikonda
Ansys EmployeeAre you reading in the rst file in 2019R1 MAPDL?
looks like the elements you selected are not valid/present?
Are you able to plot the total deformation for the whole structure?
May 15, 2019 at 4:30 am
preran
SubscriberNot able to get the stress solution and define element table. In stress solution it shows the requested S data is not available. The PRNSOL command is ignored. and in element table while adding SMISC, # it shows the requested database is not available. The ETABLE command is ignored. this is in the student version ANSYS 2019 R1.
May 15, 2019 at 7:59 pm
sk_cheah
SubscriberNot sure what element you are using. Perhaps try OUTRES, ALL, ALL before the solution.
Kind regards,
Jason -
May 15, 2019 at 8:09 pm
Serdal
SubscriberHi jason,
I used solid65, solid45 and link180 for my reinforced concrete shape. I am new in Ansys, I don't know what ? must do. What is outres, Where is it, I am very appreciate for your helping
best regards
Serdal
May 16, 2019 at 1:01 am
Sandeep Medikonda
Ansys EmployeeClick on the Results Viewer and load the RST, this should have the total deformation at least by default
If that doesn't work, try using OUTRES,ALL,ALL as jason suggested in the command window.
Take some time to go over the most commonly used commands in APDL. This article is very useful in getting started.
Additionally, the Cornell learning modules have a few tutorials that you can pick up easily from.
Sandeep
June 21, 2019 at 10:55 pm
September 13, 2019 at 12:22 pm
Martosalex
SubscriberThanks nsiwac, I had this problem and your solution worked for me!
September 16, 2019 at 2:56 pm
Ananth Narayan
SubscriberThank you nsiwac. I too had the same problem. It worked now.
October 22, 2019 at 11:57 am
alper
SubscriberHello everyone
I had some problem about mechanical apdl , thanks to nsiwac i solved one of them. but now when i try to see on graph it say'' no path data active plpath command is ignored''
Is there anyone who could help me
thanks
January 23, 2020 at 11:01 am
eugenboos
SubscriberHi, I have a very similar issue. I am calling Ansys MAPDL.exe with an input file from Python. This input file is a apdl command script. When calling the script from python the strain energy, I want to get with sene, is not callable and this error occurs in the file.err:
*** WARNING *** CP = 4.399 TIME= 17:27:16
Item SENE has not been stored in the database. The ETABLE command is
ignored.
*** ERROR *** CP = 4.399 TIME= 17:27:16
Label STRAIN_E not recognized.
The label STRAIN_E is of course the varibale I declared to be stored with SENE.
Now, I´ve already read in some discussions that setting the product launcher to "Use Shared-Memory Parallel (SMP)" and I did that. Now, the clue is, if I run the script from Ansys Classic directly via import file, it all works fine. However, if I run the script from python, it does not!
I tried to use the /PSCONTROL (/PSCONTROL,ON) apdl command in the hope of getting the issue solved but this didn´t work as well.
Does anyone of you has an idea how to solve this issue?
*** EDIT ***
I Solved the issue. The trick was using the correct launcher log commands to manually enable "SMP". This website helped me:
https://www.padtinc.com/blog/starting-ansys-products-from-the-command-line/ -
April 30, 2020 at 8:55 pm
sanketsane
Never expected that would be the solution.
August 17, 2020 at 1:08 pm
Koen_Franse
Subscriber,nI'm trying to enable SMP in an input file created from Ansys Mechanical. Can you share what APDL command you used to enable SMP?nThanks, Koenn -
September 11, 2020 at 4:43 am
apedgaon
SubscriberWhy do we need to change the HPC settings to SMP when DMP should work just fine on any PC. nAccording to me, there seems to be some bug in APDL post processor after DMP solve. I resolved this easily by selecting the appropriate result set (e.g. set,last) and it started showing results for stress. Somehow after the DMP solve, APDL loses the track of the set.n -
September 15, 2020 at 7:16 am
Chonk
Subscriberhey guys, i tried to change the performance settings from distributed computed to used shared parallel, but still i could not get the Stress results..But for the nodal solutions, there are results..and the error still shows * ansys apdl the requested s data is not available the plnsol command is ignored*...Is there any solutions for this?n -
October 8, 2020 at 8:45 am
vaibhavtaranekar
SubscriberI am trying to get results for microplane damage using cpt215 elements in ansys 2020 r2 workbench , I have used outres,all,all in element commands but the i only get results for step 1, no output when i select other steps. what to do?n -
December 20, 2020 at 6:36 pm
haydar
SubscriberTry to write SET,LAST in the command barn -
October 20, 2022 at 8:39 pm
si.sah
SubscriberThank you nsiwac!!!
It worked!
- The topic ‘the requested s data is not available. the plnsol command is ignored’ is closed to new replies.
5969
1307
