April 4, 2022 at 2:32 pm
elhamasadi
SubscriberI have a sheet plate which suffers from welding residual stresses and is exposed to transient pressure load (2 steps, a triangular profile). The problem is that once the residual stresses are present (modeled using INISTATE command), changing the impact duration does not affect the structural deformations! As far as I know, the impact time being smaller or greater than the structure's natural period must affect the solution results.
Could anyone help me through this, please?
Here is the sample INISTATE command I use to apply tensile and compressive initial stresses:
SOLU
ANTYPE,0
NLGEOM, 1
PSTRES, 1
E=70e9
Sy=194.79 !! HAZ yield stressÂ
Sc=32.2715
St=16.77
!! applying compression initial stress on plate
NSEL,S,LOC,X,0,1200
NSEL,R,LOC,Y,0,123.7
NSEL,R,LOC,Z,0,8
ESLN,S
INISTATE,SET,CSYS,-2
INISTATE,SET,DTYP,Stress
INISTATE,DEFINE,ALL, , , ,-Sc, , , , ,
Allsel, all
April 11, 2022 at 5:20 pmAshish Khemka
When is the impact taking place? Does it happen after the effect of the initial state is relaxed (say a bar elongated in the initial state is relaxed and then the impact happens) or does it happen at the same time when the initial condition is applied?
Reards Ashish Khemka
April 12, 2022 at 7:00 amelhamasadi
In the Mechanical environment, I write a command file as indicated before and apply the residual stress which happens at the same time when the initial condition is applied.
My model has welding-related issues, and it undergoes transient impact pressure loads.
Regards Elham Asadi
April 13, 2022 at 11:26 amelhamasadi
SubscriberHi I tried to apply the INISTATE command on "all " load steps and received this error:
"INISTATE data cannot be edited after the first load step."
What are the causes? Is there any solution in this regard?
April 13, 2022 at 11:27 amAshish Khemka
INISTATE can be used at the start of 1st load step only.
Regards Ashish Khemka
April 13, 2022 at 11:37 amelhamasadi
SubscriberSO do you know any other methods that I could apply the residual stresses on all steps?
Viewing 5 reply threads- The topic ‘The relationship between INISTATE command and impact duration’ is closed to new replies.
5884
1306
